Is there a Recip Compressor Rod Reversal monitoring technology?
Ok Rod Reversal Experts!
I would like to know if there is an existing technology for continuously monitoring the rod reversal of the pin in the cross head bushing that facilitates the lubrication of this section of a reciprocating compressor cylinder piston drive line mechanism.
We have experienced a condition of non-rod reversal on one of our compressors that resulted in the cross head bushing to fail due to lack of lubrication.
I have a good concept of the dynamics within this mechanism and understand that an accelerometer at 45 degrees in line with the piston shaft will show you the loading and unloading impacting in the peak to peak sine wave as a 2X RS component.
My question specifically is: Does a monitoring technology exist that one can install on the compressor that will monitor this rod reversal on a continuous basis and alarm when non-rod reversal occurs without physically identifying the condition with test equipment?
DANIEL C. SMAISTRLA
judasmai@optusnet.com.au
Equipment: Centrifugal Pumps and compressors; Steam and Gas Turbines; Reciprocation Engines and
Compressors
Specialties: Machinery diagnostics, design application of compressors, FEED,Detail Design,construction,commissioning and maintenance.
RE: Is there a Recip Compressor Rod Reversal monitoring technology?
http://dresserrand.com/insight/v7no2/art_7d.asp#
there are others listed . . .
good luck!
-pmover
Other option is to continuously monitor the temperature of pin and activate an alarm at a set value. In this case the signal has to be transmitted from the moving corss-head/con-rod to the static receiver.
Gurmeet
Time is an illusion. Now is the only thing there is.
www.detechtion.com
