3d-Hose management Question
I am trying to create a 3D layout of a product that has hose/tubing, the layout of the hose should look like " ∞ ".
I don't have a routing package, will that be easy? any idea?
can anybody give me a hint?
This is will be a part of designing a package (Like thermoformed tray)to accommodate the part.
thanks,
RE: 3d-Hose management Question
incontext sweep
That is just a hint.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
The routing package is just a fancy way to do a 3D sweep of a tube profile...with built-in bugs.  If you can do a sweep and can eff things up on your own, then you don't really need routing.
Dan
www.eltronresearch.com
Dan's Blog
