Assembly auto color
Assembly auto color
I was wondering if anyone has created a maco that will assign a unique part color to each part in an assembly. Ideally I would like it to traverse down in the order of the parts in the assembly with ROYGBIV as the first colors and then going from there with darker or lighter hues. Has anyone created a similar code before I try to go off and do it myself? Thanks.
Rob Stupplebeen
RE: Assembly auto color
Rob Stupplebeen
http://www.goengineer.com/support/downloads.aspx
it may do what you need. For some reason I remember the macro CBL talking about as coming from FCSuper... but I could be totally wrong. I went to his site and didn't see it up there.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
