Extenal batch file to export JT files
I have a batch file that I attached to the right mouse click to export jt files from NX3 part files. The result is monolithic whenever I select an assembly file.
Now on NX5, it does not work. I have tried modifying it but the result is a single jt file for each component whenever I use the external batch file.
Inside UG, it works OK. I am using the same tessUG.config file.
Here is my batch file and attached is the config file:
@rem run_ugtopv
@rem Copyright (c) 2004-2005 UGS
@rem This script selects an appropriate version of UG translator
@if not exist "%UGII_BASE_DIR%" goto :no_ug
@set PATH=D:\UGNX5;D:\UGNX5\UGII;%PATH%
@set UGII_ROOT_DIR=D:\UGNX5\UGII
@set JTK_USE_MASTER_NOTATION_PMI_FORMAT=1
@set UGII_PV_TRANS_MODEL_ANN=1
@rem This must be set to use the instance ID for CADIDs
@set JTK_XLATR_ENABLE_PERSISTED_INSTANCE_ID=1
@"%UGII_BASE_DIR%\PVTRANS\ugtopv.exe" -config="H:\a1032-pds-Roark\util\Batch_Files\tessUG.config" %*
@goto :end
:no_ug
@echo "The environment variable UGII_BASE_DIR is not set"
@echo "Exiting..."
@goto :end
:end
@rem run_ugtopv
@goto :end
:no_ug
@echo "Exiting..."
@goto :end
:end
UGNX5.0.4.1 MP6 \ WinXP-SP3
Productive Design Services
www.productivedesign.com
