Construction Managers Forum
Are you guys aware of any Construction Managers/Supervisors/Superintendents Forum? I have been googling it for a while, however I haven't run into any forum with good amount of participants. Thanks in advance.
RE: Construction Managers Forum
Post here if you have any success.
Andrew
first google hit using the term "construction manage forum" got
http
You don't say whether your are based in the states or elsewhere but there is also the construction management association of america forums / fora (?)
http://cmaanet.org/forums/cmaa-discussion-forums
From what i could see the issue could be that forums or fora aren't heavily used so you could be onto a non-starter.
Regards, HM
No more things should be presumed to exist than are absolutely necessary - William of Occam
