Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site has saved me hours of work that I cannot begin to express my satisfaction..."
Geography
mbeychok (Chemical)
6 May 09 14:46
This is an interesting article about coal-fired conventional power plants and their air pollution control systems:
http://en.citizendium.org/wiki/Coal-fired_power_plant
Milton Beychok
(Visit me at www.air-dispersion.com)
rmw (Mechanical)
6 May 09 21:26
Milton,
This is good and very comprehensive.  Did you write it?  I noticed that several of the figures scattered throughout the article were attributed to you.
rmw
Helpful Member!  mbeychok (Chemical)
6 May 09 21:39
rmw:
Yes, I wrote it and thanks for your comments. I appreciate them.
Milton Beychok
MJCronin (Mechanical)
10 May 09 12:33
An excellent article.....
I do have some suggestions for consideration...
-MJC
byrdj (Mechanical)
10 May 09 15:04
Very good article.
for the four or five sentences that I know about, I do have a correction if you like....
The entire rotating mass may weigh over 180 metric tons and be 30 metres long. The internal clearances are so close that it must be kept turning slowly at 3 rpm (using a turning gear mechanism) when shut down so that the shaft will not thermally bow even slightly and become [b]bound[b].
Another essential system is the turbine lubricating oil system which supplies oil to all turbine bearings to prevent metal-to-metal contact between the turbine shaft and the shaft bearings. The turbine shaft literally floats on a film of oil at the bearing points. This is so important that it is one of only major functions to be maintained by the emergency power batteries on site.
mbeychok (Chemical)
11 May 09 2:26
Byrdj:
Thanks very much for your suggestions. They have been implemented.
Milton Beychok
mbeychok (Chemical)
11 May 09 2:29
MJCronin:
Thanks for offering suggestions. Contact can be made via website below.
Milton Beychok
tommy75 (Electrical)
21 May 09 11:18
A very well written article. I do not see mention of Bio-Mass as a substitute energy source though. Trash, Wood Etc... Also mention of Reverse Osmosis as a potentional water purification method would be sweet. Like I said... Very well written.
Close Box
Join Eng-Tips® Today!
Join Us             Close
