spring/damper in ansys
I have another question in Ansys. I am searching for a spring/damper element that will be able to move in all direction to simulate a bolted assembly. I try with combin14, but I think that this element is unidirectionnal. In Nastran, I worked with CBUSH for that and it was great because I could specify a rigidity for every direction. So, I am searching for a element that will do the same job in Ansys. I use workbench with command line...
Thank you very much !
Simon
Simon
