ASME & minimum pressure vessel sizing
I am fabricating a pressure vessel for a testwork facility which requires 5 x individual sampling bombs equally spaced along the vessel of approx 300mls volume each. Does anyone know if these sample bombs require 100% NDT under the code?
RE: ASME & minimum pressure vessel sizing
Next time you post a vessel question, keep in mind that you'll reach a more targeted audience at forum794: Boiler and Pressure Vessel engineering.
jt
