hi, I wanna know what r the cond
hi,
I wanna know what r the conditions that should be satisfied to have a resonator.
tanx
Amir
tanx
Amir
RE: hi, I wanna know what r the cond
which one are you interested in and what frequency range?
<nbucska@pcperipherals.com>
( cca. 1500 ft.) is somewhat smaller than the wavelenght.
The impedance has to be matched to the source if you want max. power. Very often there are other, more important considerations e.g. selectivity.
Also it depends of the material Your are using to build resonator. For example in dielectric resonators, wavelenght in dielectric material is shorter then in free space. So, You can achive smaller dimensions of resonator. It depends on dielectric permability. There is a lot of possiblities.
The conditions I've mentioned are generall. There are of course lot of other ways to achive resonans.
