Advantages of a Protective Relay Network
We are currently building a new plant in which we will have all of our 5kV feeder breaker relays (Multilin) as well as 5kV Motor Protection Relays (Multilin) on a single network. This network will be tied back to an engineering station which will run multilin software (EnterVista) in order to remotely look at relay diagnostics, monitoring, event reports etc...
Seeing this as being a wonderful troubleshooting and event analysis tool, I was trying to convince the plant to construct such a network for our existing plant which uses a combination of Siemens and Multilin relays. My problem will be trying to convince them to spend the money to implement such a network.
Does anyone have any input to the advantages/disadvantages to using these protective relay networks? Is there anywhere such as a case study or some other paper where I can find information that would shown that such a network would be worth the initial investment?
RE: Advantages of a Protective Relay Network
"The more the universe seems comprehensible, the more it also seems pointless." -- Steven Weinberg
Thanks dpc!
Here's a link to the GE powerpoint on Enervista...
http://w
SEL also makes a nice system sold as PowerMax. Of course, any good sales rep is going to tell you that once you get the system installed, there's so much more you can do other than monitoring and troubleshooting. You can do dynamic load shedding, var control, etc, etc, etc.
What about disadvanteges?
What about troubleshooting of this network?
I told about industries, not about utilities.
Best Regards.
Slava
At the least, I would ensure that all of the relay passwords are not the default. I know some will argue that "our network is secure" but IMHO "no network is 100% secure."
The main disadvantage is complexity. Setting up a communications system takes a fair amount of time and effort. And then there will be ongoing maintenance, upgrades, etc. Another problem can be data overload. These devices can produce so much data that it is impossible to sort out what is really wanted. It's important to limit the data transferred to what is really needed.
Dave , Im fully agree with you, SCADA network must be dedicated network ( not connected to public network) and not connected to company internal LAN too, but in this case, we lost a remote control and troubleshooting. For utilities used 101 or 104 or DNP protocol and it another story.
For the industries, problem is maintanance of system (bays, relays)(SCADA, SAS, or what ever). Add bays, relays, changes of interlocks, etc, espesially your application Rockman, I suggest, you have 61850.
You would like add SCADAto exist plnat Siemens and Multilin, are you check FW of exist relays, communication options. It's possible, but not so simple.
Good Luck
Slava
