Manufacturing Tolerance on HR Bar Stock?
I am trying to figure out what size (thickness) bar stock to order for machining a 100" long rail whose final thickness will be 1.875"+/-.003; material will need to be 4140 normalized (i think).    We have seen bar stock come in that is bowed and twisted but has not been a concern for us since we generally can cut these into shorter lengths for our typical small piece production. But these long rails are new to us and so I am not sure what bar stock thickness to order so that I can be assured that we can mill away the twist and camber. How will I know that I can get 1.875"+/-.003 of usable thickness over a 100" length if I start out with 2" thick stock? or should I buy 2.25" stock? or 2.5" stock?  What are the rules?
Thanks for helping.
RE: Manufacturing Tolerance on HR Bar Stock?
ASTM A 108 Standard Specification for Steel Bar, Carbon and Alloy, Cold-Finished, Table A1.4:
for diameter 5/8" over, and length < 15 feet, and C > 0.28% the straightness tolerance is 1/8" for any 10 foot portion of the bar.
That means theoretically a 2" bar would suffice if the diameter was exactly 1.875".  Your cold-finished bar supplier should be able to tell you if they can meet tighter straightness requirements than those specified in ASTM A 108.
It might be in your best interest to have the bar straightened prior to machining.
TVP - the title refers to HR Bar Stock, which I presume to be hot-rolled steel.  Your data is illuminating though, since it shows that standard cold-finished bar allows non-trivial deviations, so hot-rolled bar would be even worse.
Ornerynorsk provides good advice - a little straightening can replace a lot of machining.
Note also that the stock size has a tolerance.
What you receive will _always_ be on the low side of the tolerance range, even though you pay for nominal weight.
Mike Halloran
Pembroke Pines, FL, USA
There are several proprietary alloys that will replace 4140 that can be purchased finished or semi finished. Here is one that we used quite a bit, Kromite #3 from Associated Steel. This material carries a slight premium but is well worth it.
http://www.associatedsteel.com/pdf/07-08.pdf
Another approach would be to get the bar to where it could be finished ground to size. This approach minimizes the distortion caused by machining a HR bar.
http://www.americangrinding.com/divisions/grinding/
