Valve Dimensions
Valve Dimensions
Does anyone know of a good source to obtain specific Fisher valve dimensions? I need accurate dimensions to determine the mounting dimensions of electraulic actuators I am looking to install.
Any and all information is greatly appreciated.
Thank you!
Dave
Thank you!
Dave
RE: Valve Dimensions
Without even trying a search engine first i though: "Fisher valves.... why not try www.fishervalves.com"
This brough me to the front page where i selected "products" and got to here:
http://www.fishervalves.com/home/products/index.html
scolling down a little says "Control valves and valve-related instrumentation" and a link to "fisher" tried that and got:
http://www.emersonprocess.com/fisher/products/index.html
have a look C yourself - and maybe try this _before_ posting another time?
Best Regards
Morten
Thanks for the help.
i found this brochure:
http://www.documentation.frco.com/groups/public/documents/bulletins/d101363x012.pdf
It gives you face to face dimensions (including ansi B16.10)
Best Regards
Morten
If I understand correctly what you are looking for you'll have to contact Fisher directly for the bonnet interface dimensions. However, unless you are the actuator OEM they may be unwilling to provide you the information you are looking for.
