create element on node in Workbench
I want to know if is it possible to create a "cerig" from a command line in workbench like we do in Classic ?
RE: create element on node in Workbench
mnode = node (X,Y,Z)
where x,y,z is easily obtainable from your point mass description in workbench. I hope that answers your question.
Since I don't know what your working on, you might want to investigate remote displacements and being able to set materials behavior to rigid.
I have an other question. I wrote ansys commands into workbench to constraint nodes, but, when I solve my model, Workbench put some weak spring because it doesn't detect any constrait (they are on my command line, workbench doesn't see them). Is someone know a way to remove theses springs ? With these springs, my modal solution gave me only the frequency of the springs.
THX
Simon
I have an other problem (Sorry I am learning Ansys...)
My nsel command doesn't works : The item label 8000 is not recognized by the nsel command...
