HELP WITH MACHINING & THREADING TUNGSTEN
I HAVE TO TURN & SCREWCUT 10MM STOCK BAR TO GET AN 8MM THREAD X 9MM LONG HOW CAN I STOP THE CRUMBLING EFFECT I AM GETTING?
RE: HELP WITH MACHINING & THREADING TUNGSTEN
Now, is the crumbling occurring when you machine to an external corner? If so, use a support made out of a machinable thermoplastic material such as nylon. Also, use a large chamfer that is machined before the adjacent surface is machined. This chamfer should be sufficiently sized such that there is some metal still left after the turning cut is complete.
source: ASM HANDBOOK Volume 16 Machining
If you don't have this reference, then you really need to purchase it, especially when machining difficult materials like tungsten.
