Rc Design Results True?
This model in the attachment is a sample building with limited random load combinations in order to test the RC Designer "Column Design" Results.
I have used ACI-318-05 with default brief data and by selecting all load combinations.
I am not satisfied with the As provided results because the program does not check the "most critical LC" for most of the columns.
