NASGRO software
NASGRO software
NASGRO software
Hello all,
I have been asked to perform Damage tolerance on a component using a specific software called NASGRO.  I went to NASGRO website and noticed the cost of the software is 3600$ and not really eager to spend that much for a task I will probably use for 1/2 hour task
I noticed in the forums on the website, there was once a free copy of this provided to public domain but due some reason NASA (or owner's) removed it from the internet).
Any assistance on locating this copy would be greatly apprecited
RE: NASGRO software
If you've been specifically asked to use the program either yourself or your company agreed to perform the work with the subject software....time to open the wallet.
RE: NASGRO software
Maybe you can rent the program on hourly basis.
Another option is to use AFGROW which is still free. See http://www.afgrow.net/ . AFGROW uses NASGROW 3 as one of its options. If your part shape included in AFGROW you may be able to use it.
RE: NASGRO software
NASgro was free many version ago ... they do have a demo version.  do you know why you were told to use NASGRO ?  if it's going to be a once-off, you'll spend more time learning the software than solving the problem.  if your company plans for you (or someone else) to do more work in the future then spend the $s.  if you're "just" doing DTA, then a simple cycle counter is "all you need ... i use excel.  the trouble is convincing other people that the analysis is good.  you could try AFGROW, which was freely available some time back.
