Asynchronous Generator
Hello all,
One 20 years old three phase asynchronous generator: 135 KW 400 V 50 Hz 1565 RPM ussed in winding generation was removed from service and now the owner wants to use in South America so the machine will be run with a new gear box (The machine most generate at 60 Hz) , the costumer is interested in to know pro and con,and they want to be absolute certain this old machine will not faill.
What do you think about it? s better rewind? could we offer a guarantee if the generator is not rewound?
Thanks for the inputs
Petronila
Petronila
RE: Asynchronous Generator
The kW can maintain same at a lower output current and corrsponding lower copper losses.
