Unfolding error
Unfolding error
Please take a look at the attached sheet metal part. When I click the unfolding button I get an error. If I suppress the holes on the side wall I don't get the error anymore. Those holes should not affect in any way the folding/unfolding. Can anyone explain what's happening? Is this a bug? I am using SW2009x32 SP3.0, Win XP x64, Quaddro FX-3500, 4 GB of RAM.
RE: Unfolding error
I get the same error as you. I even deleted the dimensions and changed from "up to next" to "through all", but the error persists. I am also on SWX09-SP3.0.
It looks like a bug to me. Have you sent this to your VAR?
- - -Updraft
RE: Unfolding error
RE: Unfolding error
RE: Unfolding error
RE: Unfolding error
RE: Unfolding error
RE: Unfolding error
RE: Unfolding error
is the K-factor (0,01) in your model correct? I try it with K-factor 0.5 and everithing is OK.
