Speedpak question
Speedpak question
I'm using speedpak in SW9, and I can't find a way to include planes.
Here's my assembly structure
A
-B
--C
---D
I have a component in D that has a Right plane, and I am using that plane to position B within A (it makes sense functionally).
I made a speedpak config of B that includes part D, but I can not access the plane, so when I switch to the speedpak config, it can't solve.
Any suggestions?
A
-B
--C
---D
Any suggestions?
RE: Speedpak question
I am almost sure you cannot pick planes in SpeedPak.
Another issue to look at:
When you create a SpeedPak assembly and then use that assembly to build a drawing, the balloons match the Bill of Material. However, now you use that SpeedPak assembly in the next level drawing and point to the SpeedPak assembly you will find a * in the balloon bubble. I tested this in SolidWorks 2009 SP1.0 not SP3.0.
Standing
SolidWorks Pro 2009 x64, SP3.0, PDMWorks Workgroup, SolidWorks BOM,
HP xw8600, 64-bit Windows Vista Business, Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB, nVidia Quadro FX 4600
