Melt tempreture
Melt tempreture
Does anyone knows what is the minimum and maximum melt temperature for EP332L Polyproplene.
I need the melt temperature in order to figure/determine the holding pressure graph i.e process window.
Clifton
Clifton
RE: Melt tempreture
Have you tried http://www.matweb.com/index.aspx.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
RE: Melt tempreture
Thanks for your reply... I have the following article but unfortunatley i had no luck....
http:
Mainly the melt temperature should be around 230 deg celcius.
But in order to do the holding pressure graph i.e process window i need the minimum/maximum.
RE: Melt tempreture
From the link above - Table on page 15
Flow Characteristics Melt Temperature
Range, °F (°C)
Low flows 475-500 (246-260)
Medium flows 445-475 (228-246)
High flows 400-445 (200-228)
Extra high flows 385-420 (200-215)
Ultra high flows 370-385 (185-190)
H
www.tynevalleyplastics.co.uk
RE: Melt tempreture
but it does not specific for Polyproplene EP332L.
RE: Melt tempreture
We can give general replies, but t answer accurately, we would need to determine who the manufacturer is then contact them or we would need to go to matweb for you. You can just as easily do it for yourself.
Pat
for site rules
RE: Melt tempreture
The manufacturer is Mopelan Basell....
RE: Melt tempreture
RE: Melt tempreture
With an MFI of 7, I would put it in the medium class - 228 to 246C.
H
