Valve to throttle flow in a force main
I have a grinder pump station where an automatic sampler will be required to sample the effluent from the station. Since the sampler needs "non pressurized" flow and a stream of about 15gpm, the manufacturer's rep has recommended a loop be constructed immediately at the start of the force main.
It's a 3-inch force main and the loop will be a 1.5 inch PVC going right back into the wetwell, which will be throttled through the use of a valve to achieve the desired 15gpm. The manufacturer's rep has recommended just using a pvc ball valve in this case, but I'm not sure what other options I might have. Normally we wouldn't use a ball valve in wastewater applications but perhaps it's OK on a bypass loop such as this?
RE: Valve to throttle flow in a force main
I wouldn't be really keen on making a bypass loop like you are talking. 15gpm bypass will really hurt the efficiency of your grinder pump.
http://www.bvssamplers.com/BVS_Info.pdf
bimr, I spoke with the folks at BVS, sounds like this is another option, albeit more expensive. Options are always good...thanks!
