Piezo material properties for ANSYS
In ANSYS you can import material properties of piezo ceramics. But where can I find the specific material properties that are required by ANSYS?
You can find all kind of piezoelectric material properties on the net, like:
http://www.efunda.com/materials/piezo/material_data/matdata_output.cfm?Material_ID=PZT-8
or
http://www.matweb.com/search/DataSheet.aspx?MatGUID=ce802bd7a06b4b2f9f539e7c2c141f75
however, those are not compatible with what ANSYS requires. Where can I find the data that ANSYS requires?
The data that ANSYS needs:
! Material properties for PZT-4
mp,DENS,1,7700                 ! Density, kg/m**3
tb,DPER,1                      ! Relative permittivity at constant strain
tbdata,1,729,635,729
! - Alternative input of permittivity if used with SOLID5
! mp,PERX,1,729
! mp,PERY,1,635
! mp,PERZ,1,729
tb,ANEL,1                      ! Anisotropic elastic stiffness, N/m^2
tbdata,1,13.9E10,7.43E10,7.78E10  ! c11,c13,c12
tbdata,7,11.5E10,7.43E10       ! c33,c13
tbdata,12,13.9E10              ! c11
tbdata,16,2.56E10              ! c44
tbdata,19,2.56E10              ! c44
tbdata,21,3.06E10              ! c66
tb,PIEZ,1                      ! Piezoelectric stress coefficients, C/m^2
tbdata,2,-5.2                  ! e31
tbdata,5,15.1                  ! e33
tbdata,8,-5.2                  ! e31
tbdata,10,12.7                 ! e15
tbdata,15,12.7                 ! e15
