Use of Solenoid Valve in Heat Pump Liquid Line
Carrier Residential Heat Pumps specify that if lines are longer than 90ft that a bidirectional solenoid valve be placed in the liquid line near the outdoor unit to eliminate refrigerant being able to flow back into the Compressor unit during the OFF cycle.
1) I am thinking that this must be to prevent the refrigerant from flowing back into the outside coil during HEATING mode? Is this correct? Is this a problem during COOLING mode?
2) is this a cure for a potential compressor "slugging" problem or is it to prevent the liquid from carrying heat from the building back outside and thus an efficiency issue?
2) Since these units use an "orifice" during heat pump HEATING mode, (instead of an expansion valve), the liquid can obviously flow back into the coil. I am wondering if putting a HP expansion valve (one way expansion valve, other way just a check valve, same as used in the inside unit), in the heat pump outdoor unit liquid line, would work as well? It seems like a hard cut off expansion valve would also prevent liquid flow back into the outdoor unit.
Can someone illuminate me on these points please?
Thanks.
Joe
Thanks.
Joe
RE: Use of Solenoid Valve in Heat Pump Liquid Line
However, I am not aware of exactly how much refrigerant an expansion valve will allow past after the compressor shuts off. Obviously, the solenoid valve shuts off completely once the compressor shuts off.
The Infinity Heat Pump uses a metering orifice going into the outside coil during heating mode. Does anyone know if the efficiency would be improved enough to matter if an expansion valve was used instead?
