Beam Splice Deflection Question
I designed a beam to be erected under a floor in an existing office building to hold up storage units above. Deflection is the critical item. I requested splices to be designed by the Fabricator's Engineer for the full moment capacity of the beam. What I got developed the moment due to the area of the flanges.
My question is this, wouldn't this splice that is designed as described above reduce the moment of inertia, thus increasing deflection?
RE: Beam Splice Deflection Question
It would be better to ask the connection design engineer to develop strength capable of resisting "full anticipated reactions", rather than just moment. Also, if the splice can be made in the shop, a full-pen weld over the joint is the most easy way to handle this type situation.
BA
BA
Beautiful. Delight to see the solution. The deflection could be small, but is there. Nice to have a simple method to check on it.
BA
