Create Struct using variable values?
Is there a way to create a struct using the value of a variable?
For example say I had the following variables:
league='MLB'
team='Phillies'
How can I create a struct that looks like the following using the variables league & team:
MLB.Phillies.player1='Utley'
Is it even possible?
RE: Create Struct using variable values?
Anything is possible if you cross over into the dark side and use "eval".  Don't expect your code to be readable though.  Do expect your workspace to become flooded with variables.
- Steve
I did find a round about way to do it using "eval".  It ain't pretty, but it works.
