ASYS-CFD\FLOTRAN analsys for blade passage of axial flow compressor
hi evry one:
i need to know how can i simulate the flow through the rotor blades of axial flow compressor of gas turbine engine. is the feature of rotating frame of reference is useful in this task, how can i do it. if you have experience in simulting rotating parts in action with stator parts this will be very usefull to me......
waiting for your response.
bye........
RE: ASYS-CFD\FLOTRAN analsys for blade passage of axial flow compressor
how the example of cfd llotran analisis 3d
Sheb,
Apply moving wall on faces attached to blades (define lods>CFD>velocity>on lines---click on moving wall and ends, donot apply any velocity Valus----say ok)
go to Flow environment>rotating coord> apply speed in particular axis in rad/sec and donot forget to apply offset from global axis)
M A PASHA
ASSOCIATE GROUP LEADER
CADEM
TECUMSEH INDIA
HYDERABAD
