BOM issues, 2009
BOM issues, 2009
I've created a Bill of Materials in a drawing in v2009, but many of the cells show not my part name/number, but "PreviewCfg" instead (in the Part Number column). As best I can tell this is usually with Toolbox-based parts.
Whatever I do, I cannot seem to get the true name of the part to appear in this column. Anything I'm overlooking here?
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
RE: BOM issues, 2009
Eric
I've had this happen in v2007, but when I change the options in the configuration's properties, it solved the issue (like you mentioned). Again, even in v2007 I saw this only for Toollbox-generated parts.
Maybe I'm missing some other option that needs to be selected in tandem? I'll keep digging around.
Jeff Mowry
Jeff Mowry
