BOM Header Modifications?
I'm exporting a BOM to a CSV file.
I need to tweak the header a little bit.
For example... I would like to change the "ITEM" column name to "FindNumber".
Also, I need to add a line of text before the column names.
Is there a way to do this?
RE: BOM Header Modifications?
Thanks but... we are already doing that.
I'd like to take that step out if I can.
What exactly are you trying to do with this csv file?
The database we are importing to... is looking for a specific format.
We don't have any control over the database code so I was hoping to tweak the output directly from Inventor.
???How would a macro add steps???
You can write a macro that makes the process simply pushing one single button in Inventor and it would prepare the csv file exactly how you wanted it.
Yeah... we would use this quite often.
