Read-Only RSLgix 5
Read-Only RSLgix 5
I am trying to set-up a read-only version of Rockwell RSLogix-5 software for my technicians to use to troubleshoot our processes without having the ability to do anything other than read logic and data table values: no changes allowed. I've tried the RSLogix program/file passwords, but when I go online, it defaults to class 1 with all the priveledges. Lower class defaulting only seems to work in offline mode. Is there a way (start-up switches, other vendor products) that will provide me with a solution? We are also looking for this for RSLogix 500 as well.
Thank You in advance for your help..
John Hellmers
John Hellmers
RE: Read-Only RSLgix 5
Rockwell used to bundle it with some other products, check with your AB rep for a demo if one exists.
Hope that helps.
