Proferal - a gray cast iron?
I am currently investigating a fractured cam shaft from a V8 engine.  I have tracked the material specified for this shaft as a "proferal cast billet".  I believe this to be a grey cast iron?  If so do you know where I could obtain material chemical composition/mechanical propety data for proferal?
RE: Proferal - a gray cast iron?
Suggest you cut a piece out from the cam and do a micro examination and hardness test on it.  Before destroying the part though make sure you take plenty of photos.
Good luck
