blocks and stuff
blocks and stuff
Hi all,
Has anyone had any experience using sketch blocks to display motion paths? I am experimenting now using cam paths to move levers and stuff. I've seen demos but never tried it. As I understand it, you can create a sketch, make it a block then create other blocks and relate them to each other to control their degrees of freedom. Any thoughts?
SW2007 sp4
SW2007 sp4
RE: blocks and stuff
Dan
www.eltronresearch.com
Dan's Blog
Thanks for the tip. I am trying to create simple motions using cam profiles, driving lever arrangements as a quick way to display and interpret motions.
I have created a single block with two cam paths, each driving its own lever arrangment. I've used fit spline and simplify spline tools to ease the transitions and inflection points of the profiles and are still experimenting. I dont seem to be able to get smoth motions from the cam paths. I would like to add two more profiles to the cam block with two more levers.
Anyone think I'm exceeding SW capability here?
Can you zip and post the relevant files so we can test on our machines?
Making a cam path from multiple segments is a bit tedious. I use Fit Spline to create the path for the entire motion.
Take a look.
Tick
Fit Spline and Simplify Spline work easily enough but change the cam path, no? What tolerances are you using with these tools?
See attached file
Dan
Dan's Blog
The profiles are not random as they were created from the cam designer in SW. What do you mean by "bumpy"?
Is there a tool to smooth the curves more so than the simplify spline tool?
