How to change default model dimension size
Hello -
Is there a way to globally set the size that model dimensions are rendered at? I don't like the large font used in sketches and when I select a feature to edit. On a busy sketch the dimensions all run into each other.
Thanks in advance...
Ed
Ed
RE: How to change default model dimension size
There's also a box somewhere for "always display dimensions same size" or something like that. It's a good setting for parts.
-handleman, CSWP (The new, easy test)
Ed
