slug catcher water removal after hydrostatic pressure
We are in the final stage of the construction of a natural gas slug catcher. We are looking a way for removing the water after hydrostatic test pressure. The catcher has only two nozzles, one for drainage and one for level measurement (4"). Both nozzles are installed appr. 3m high from the catcher's main pipes (as the vessel is installed underground with it's nozzles above ground) and it is not easy to remove or rotate the vessel so as the water could be removed for the nozzles by gravity.
The catcher is vessel pipe 24" appr. 2x6m pipes and has a volume of 4000lt.
RE: slug catcher water removal after hydrostatic pressure
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Seriously, why can't you pressure it up and blow the air out the normal flow path?
David
