flexural-torsional buckling of single angles
The code says that FTB of singly symmetrical angles does not need to be checked- my question is why?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: flexural-torsional buckling of single angles
If so, it's akin to bending about the weak axis of a wide flange, it simply cannot control.
Mike McCann
MMC Engineering
That's "allude"...
al⋅lude
/əˈlud/ [uh-lood]
–verb (used without object), -lud⋅ed, -lud⋅ing.
1. to refer casually or indirectly; make an allusion (usually fol. by to): He often alluded to his poverty.
2. to contain a casual or indirect reference (usually fol. by to): The letter alludes to something now forgotten.
Origin:
1525–35; < L allūdere to play beside, make a playful allusion to, equiv. to al- al- + lūdere to play
Synonyms:
hint, intimate, suggest.
tg
Mike McCann
MMC Engineering
Mike: Twisted, without check per code :)
Mike McCann
MMC Engineering
Others, if you wish to critique my grammar please do so in another thread. thanks.
Working from memory without the code in front of me was not a good idea. It appears I pulled information from my rear.
I know you were talking about FTB, not LTB but I wanted to use the analogy; However, it appears that LTB does, in fact, need to be checked for angles in flexure about the Z axis. Even so, there are some limits placed on when it does and does not control, aluding a bit to what I was talking about.
You can certainly do the following if you have a case that seems outside of E5:
Compute Qs per E7.1(c).
Compute Fe per both E3-4 (FB) and E4-5 or E4-6 (FTB)
Compute Fcr per Eq. E7-2 or E7-3 (slender) or E3-2 or E3-3 (nonslender)
Compute Pn = Fcr Ag
Don't forget that your load might be attached with an eccentricity, so you might have a moment about one or both axes. Compute phiMn and then use interaction equations in Ch. H.
Compare what you get with results from E5.
No meaning. Just try to stop my choking.
Mike McCann
MMC Engineering
