REULAND Nema Motor
REULAND Nema Motor
REULAND Nema Motor
I am in IEC motor land but need the following or an equivalent but it must be Nema:
REULAND HP25 RPM 1500 FRAME 286U
SER C94-5955B-3 TYPE Y000
PROD NO 02500-1GAN-0006
PH 3 HZ 50 VOLTS 190/380
AMPS 75/37.5
ENCL VENT STYLE AVO
INS SYS B TIME RATING CONT MAX AMB 40
This is the text i was given from a site guy, don't if it is drip proof or IP55, if anyone can help with sourcing in Europe that wold be great
Cheers Feg
RE: REULAND Nema Motor
Any reason you can't get the original rewound?
Where abouts in IEC-land? The rest of the world is a big place!
The NEMA world has gone to T-frame motors.  Older U-frames may still be around, but I can't say for sure.  Re-winding may be the only option without replacing the motor with one of a different frame.
Did you try contacting Rueland? They are a very accommodating bunch. If your "IEC country" happens to be in Asia, they have a rep in Hong Kong.
http://www.reuland.com/
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Reuland is your best bet, after rewinding.  And, U frames are still very much around and can be had new from several motor manufacturers.
