Gear Box Torque Question
Just wondering if the torque output on a belt drive is directly proportional to the ratio of the belt drive?
I have a motor with a rated speed of 1185 RPM and a pump with a rated speed of 372 RPM.
The rated torque of the motor is 1187Nm.
Would the torque applied to the pump be equal to:
pulley ratio = 1185/372 = 3.2
torque = 3.2 * 1187 = 3798Nm
RE: Gear Box Torque Question
Yes, (less friction losses).
Usually minimum of 5% or so.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
