Heat Transfer
Heat Transfer
Heat Transfer
4 Barg superheated steam is supplied to the jacket over a sulfur line.  Will the sulfur be heated above the condensing temperature of the steam?
RE: Heat Transfer
Depends.
rmw
RE: Heat Transfer
Probably not, unless there's a lot of superheat. It's a far better practice to use saturated steam for heat transfer purposes such as this. Almost all of your heat is latent heat.
