Damping coefficients for ground types (seismic engineering)
Can anyone explain to me/point me in the direction of some good resources on damping coefficients for different ground types?
I know the waves propegate differently through different material & if you are on a soft ground your loading will be more severe than if you were on rock...and that say if you are on a hill the loading will be more onorous but i'm not sure how to calculate the effect of any of these aspects!
Any help would be appreciated!
RE: Damping coefficients for ground types (seismic engineering)
Anyway...If it's for concepts and the math, because I have it handy, I use "Soil Dynamics" by Tien Hsing Wu, originally published by Allyn and Bacon in 1971, then self-published in 1975. Not sure how easy it is to find. I haven't read it, but you might try Steven Kramer's book on earthquake engineering of dams, which probably has good info on response analysis, which would have include strain-dependent damping, modulus reduction, and all that stuff; and a dam is kind of like a hill.
The hill will quite likely require a 2-D analysis (QUAD4M, QUAKE/w, FLAC, PLAXIS), not 1-D (SHAKE).
