Waspaloy creep >1000 hr
I am looking for creep properties for Waspaloy beyond the 1000 hr data that seems to be generally available. Any ideas? Thanks.
Waspaloy creep >1000 hrWaspaloy creep >1000 hr(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Waspaloy creep >1000 hr
Mind if I ask why? If this is a new design then you aren't using this alloy.
You must be working with some old equipment?
Plymouth Tube
Did you try Haynes International or ATI (Allegheny technologies)?
Corgas,
I'm curious about your comments regarding use of this alloy for new designs/equipment. Are you assuming the product form to be plate/sheet/strip and the end use is a land-based gas turbine? My familiarity with this alloy is in the form of bar/rod/wire for high temperature fasteners used in aerospace gas turbines, of which this is still contemporary practice. The datasheet from Special Metals shows 14 different SAE AMS and AECMA PrEN standards for Waspaloy bar/rod/wire, and numerous aerospace manufacturers like SPS and Alcoa show "standard" products that they manufacture in Waspaloy.
h
http:/
There is a lot of spec coverage for 625 still too, but that doesn't make it state of the art.
Plymouth Tube
Thanks for the additional information. Would you mind jotting down some of the alloys that have higher creep strength than Waspaloy? I'm curious if any of them are offered in bar/wire/rod for fastener applications. SPS offers Alloy 718 or the proprietary grade Aerex 350, but that is about it in terms of high temperature, creep-resistant grades.
See the attachment below. I started to compile some data but ran out of time. This is from a Gas Turbine Alloy Handbook.
http://
