AISI Equivalent of BS EN 10305 E220 grade Mild Steel
Hi All,
I'm looking for the material properties of E220 grade Mild Steel. The part in question is a flat oval tube made to British Standard BS EN 10305-3:2003 or -5:2003.
I know that I can use Matweb to easily find the properties of the grade, if I have an American equivalent.
I have looked at various conversion sites etc, but haven't been able to find the AISI grade required.
Many thanks,
AutoSpace
Many thanks,
AutoSpace
RE: AISI Equivalent of BS EN 10305 E220 grade Mild Steel
I may be looking in the wrong location, but haven't been able to find either the grade or the spec you mention. Could you point me to where I might find it?
Thanks.
It is a little more difficult to find mechanical properties of semi-finished products like welded steel tubes using Matweb or similar. The specification requirements for E220 (1.0215) +CR2 according to EN 10305-3 are as follows:
ultimate tensile strength = 310 MPa min
yield strength = 220 MPa min
Elongation after fracture = 23% min (gauge length Lo of 5,65√So)
As I understand, "CR" denotes Cold Reduced. What does the "2" indicate. Also is the (1.0215) a part of the spec. req. or part of the definition of the steel grade?
Also if you have similar figures to hand for 10305-5, I'd be most grateful if you could post those.
All the best,
AutoSpace
DIN EN 10305-2 uses the following explanations for defining the +CR2 delivery condition:
Welded and cold sized: +CR2 c Not intended for heat treatment after the welding and sizing process
c NOTE 2 If further heat treatment is applied, the resulting mechanical properties may be outside the specified requirements.
