Using linear and circular patterns together?
I have created a model using planes to align the four holes.
Can I use patterns instead?
I can pattern the first hole using a linear pattern measuring 50mm but need to combine it with a radial pattern of 30 degrees. I end up with holes that I do not need.
Is there a way to combine the two?
RE: Using linear and circular patterns together?
Dan
www.eltronresearch.com
Dan's Blog
