How to calculate energy saved in HVAC Duct?
I have two different materials for air ducts.  If I have cool air flowing through the first duct, the temperature difference between the inlet and outlet of the duct is 3 degrees C.  For the second duct it is 5 degrees C.  The first duct is obviously a better insulator, but how do I quantify how much energy is saved from the first duct compared to the second duct?
Jeff
RE: How to calculate energy saved in HVAC Duct?
mass flow rate x specific heat x temperature difference
Or simpler yet:
1.07 x cfm x temperature difference
What units does that give me (the 1.07 x cfm x delta T)?
This sounds like homework to me.........
It isn't homework, it's trying to help a structural design engineer remember thermodynamics and heat transfer which has escaped me.
Thanks for your help.
BTU/hr
