R17 TO R19 Where did the "Edit Formula" option go in Properties?
In properties in V17 I could add formulas using the right click on Other properties when they were defined as a length. Now in V19 that option is gone.
Anyone have a work around?
RE: R17 TO R19 Where did the "Edit Formula" option go in Properties?
Just checked and was suprised to see the change, but you can still set it through the formula feature, filter for user parameter to find them faster
It is hit or miss, depending on which function you are talkiing about.  It looks like an accidental omission.  You can access "edit formula" in different ways on different functions, but the surefire way is the paramter function, as Azrael mentioned.  Sometimes, you can access "edit formula" by right clicking only, sometimes, you have to access the intrinsic parameter, (as in pad length - you would have to open the Pad object) and sometimes you won't find it in either place.
By the way, this condition is present in R18, as well. (just for those who might go looking)
Catia Design|Catia Design News|Catia V5 blog
