shell pressure test
shell pressure test
I have a question for the pressure test equipment capability.
If I want to test a valve with 1000 psi shell pressure, can I use test equipment with 1200 psi maximum pressure capability?
I heard that the hydrostastic pressure tester shall be 4 times the pressure rating of the valve.
Please advise
Please advise
RE: shell pressure test
4X sounds kinda' high, but not knowing the spec, everythings ...
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Open to comment!
