Adding inspection numbers to dimensions
This topic was covered in the past and the posting has been closed, http://www.eng-tips.com/viewthread.cfm?qid=205851.  However, the macro posted by Handleman, a macro guru, will not work in SW2009.  I have tried this on two computers and get the same results on both, Compile error: Can't find project or library, with Sub AddDimRefNems() highlighted yellow.
Since I know about as much about writing macros as I do about the dust on Pluto any help would be appreciated.
RE: Adding inspection numbers to dimensions
You may have to fix references to make it work after upgrading to 2009, but the code still works.  Edit the macro and go to Tools->References in the VBA editor.  Un-check any missing 2008 (or earlier) references and find their corresponding SW 2009 version.
Alternately, if you are pasting the code into a new macro, make sure it is a VBA macro and not a VSTA macro.
-handleman, CSWP (The new, easy test)
