UK budget prices for steel
anyone know the general estimating price per tonne for uk steel with simple connections.
I have 150UC struts about 6m long which are galvanised and have pinned connections each end.
RE: UK budget prices for steel
This can be a tricky one.  My first port of call for accurate information would be an up to date Spons guide in accordance with SMM7.
http://www.ricsbooks.com/productInfo.asp?product_id=17580
Second would be to check out any recent tenders that have come in, and call some local fabricators
We tend to use about £3000-5000 per tonne fabricated for offshore structures (depending on tonnage) but these are generally heavier that typical buildings, and involve a lot of welding.
The last info I have for buildings was from the start of 2006,  £1500-2000 per tonne for London, and £1200-1800 per tonne elsewhere.  If you could get your hands on the latest BCIS indexes you could bring these up to today.
Thanks ussuri,
Yes I am having problems dowloading the BCIS index as the website doesnt seem to be working. I will base my budget pice on £1800 per tonne as it is a small job outside london.
Even if the website was working, you need to be a member to get the indices.  They are quite protective of them.  I guess if engineers had access to all the current cost information there would be no need for QS's smile.
I would recommend Spons, i used to find it really helpful and its certainly a lot more accurate.
http://www.steelconstruction.org/steelconstruction/view?entityID=345&jsp=news_viewer&sessionID=-1235535604698&;entityName=newsitem
If you've got an email address I can send the BERR Indices to March 2009, are they of use?
Thanks debaser butn I managed to download those from the ihs.
I have used 1800 as a good rough figure for cost comprison.
