Nitronic 50 Temperature Data
I am in need of some temperature data for Level 4 Coldworked Nitronic 50. What is the tensile and yield strength of Nitronic 50 at 400 degrees F. Are there any temperature lists available for this material. I appreciate any pointers.
Thanks Chris
Thanks Chris
RE: Nitronic 50 Temperature Data
Plymouth Tube
I have old, old Armco data on Nitronic 50 that shows the following for 54% cold swaged
Temp UTS YS
RT 230 216
200 215 205
300 206 199
400 200 194
500 195 191
If I recall correctly the numbers posted by MikeMet are for small diameters. We used 135 UTS as the practical max for anything above 1 1/2" in diameter
