PMI callout properties wrong values
I wish to display values of MI of model using PMI callout. I go into callout properties and select "Property Text" and "from active document" and select the variable I need, for example Izz.
Sometimes value is correct and other times it is incorrect, that is different from value as displayed in "inspect" "physical properties".
Am I failing to update to get current values or picking wrong variables?
Please help?
Please help?
RE: PMI callout properties wrong values
Mass props are not automatically updated during model edits, so you need to manually update or they will update on saving the file. Try it.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
PMI --> 'Update All Property text'
as well? Otherwise they will get updated only when doing
a Close with Save and then reopen the file
dy
Why so many updates? You would think one would do. And update all would work for everything. I am sure there is a good reason
