cracked section
cracked section
Hello guys,
I have a silly question to ask about the UBC97: following the requirements of UBC97 1630.1.2 in my 3D model of a Concrete structure I have used the reduced Inertia properties following the
requirements of ACI 318-05 section 11.10.1. The question is: It is not clear to me if I have to use the "cracked model" only for the Evaluation of the displacements or also to design
the reinforcement of the columns and beams ?
Thank you in advance
RE: cracked section
Hope this can help
