PQR tests per AWS D1.1
Refer to ASME Section IX, Tests for PQR including
1. 2 pcs Tensile Test
2. 4 pcs Ben Test
I am not familiar with AWS. Tests are as same as Section IX, aren't they?
What about VT,RT or UT and Macro, they are mandatory required tests on PQR speciments per AWS, aren't thay?
QualityAsia
2. 4 pcs Ben Test
QualityAsia
RE: PQR tests per AWS D1.1
VT, and either UT or RT are required per AWS D1.1
Macros are typically used for fillet weld qualification or overlays.
The thickness limitations of ASME IX apply only to the thickness of deposited weld as related to the joint(s) of a full or partial penetration weld and not to fillet welds.
AWS acceptance criteria is more stringent than ASME. AWS limits for the bend tests are no open discontinuities larger than 1/8 inch and no greater than 3/8 inch when summed. ASME has no sum limitation.
You may also want to check local and state building codes. Some engineers are not willing to push the envelope when building codes specify AWS for structural applications. Likewise, they do not accept AWS qualifications when they are working in a state that requires conformance with ASME for pressure vessels and piping systems, etc.
